is the progamme is write for running of internal EEPROM of PIC16F877A microcontroller
bikash123
Tezpur University
Plz help me.
i have written one programme of internal EEPROM with PIC microcontrollers. Is the programme is right to run. plz tell me the connection diagram. the compliler is microc.
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
char *txt1="current";
int I,V;
Lcd_Init();
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
void main()
while(1)
current_read();
txt1= " current";
Lcd_out(1,1,txt1);
Delay_ms(2000);
ADCON1=0x22; // A/D Conversions of input voltage
TRISA= 0xFF; // All input Pins of A are connected as inputs
void current_read()
V= ADC_Read(2)* 5000/1024;
I = V - 2.5;
FloatToString(I,str)
Lcd_Out(1,8,str)
Delay_ms(10);
Why are you asking for connections again? I have answered you in this post:
https://www.edaboard.com/threads/252004/#post1078380
Why don't you try actually wiring it up, then see if your code runs?
Also, please remember to use the code or syntax tags for your code, as I mentioned.
i am trying more than 10 times but the problem where is occurring i am unable to find. After burning to that programme in microcontroller directly is it connected with LCD. as per the the LCD programme. or when i will give ANALOG input in pinAN2 that will store and after then it will display. Plz help me.
# 1
Is this progrmme is for pic16f877a microcontroller for internal memory .
whether is my false, that it is not displayed.
void WriteEEPROM(char Addr, char Data);
char ReadEEPROM(char addr);
void port_confg();
Lcd_Init();
void main()
char WriteEEPROM(char Addr, char Data);
port_confg();
Delay_ms(2000);
while(1)
void port_confg()
PORTB = 0;
PORTA = 0;
TRISB = 0b00001111;
TRISA = 0b00100000;
while(EECON1.WR == 1);
EEADR = Addr;
EEDATA = Data;
EECON1.EEPGD = 0; // 0 = Access data EEPROM memory
EECON1.WREN = 1; // enable writes to internal EEPROM
EECON2 = 0x55; // Required sequence for write to internal EEPROM
EECON2 = 0xAA; // Required sequence for write to internal EEPROM
EECON1.WR = 1; // begin write to internal EEPROM
EECON1.WREN = 0;
EEADR = addr;
EECON1.EEPGD = 0;
EECON1.RD = 1;
asm nop; asm nop;
return EEDATA;
high plz help me
