Bipolar signal driver
djnik1362
Full Member level 2
Full Member level 2
IRAN
Hi
I need to design a custom Bipolar Signal Driver.
This signal transmitted with two lines . One line have signal with +15 V and -15 V and the
other line connected to ground . On the other side there is a differential receiver which when
one line be greater than return (GND) line then produce logic 1 and when the line be negative
then produce logic 0 .
How can i produce such a signal ?
Levels are important . (+-15 V).
Thanks for your support.
Perhaps worth considering an established standard. The problem with the proposed scheme is that if you're just testing for
anything positive or negative compared to the ground line, then what's the point in driving to +-15V?
Surely you should be testing for anything (say) greater than +10V or less than -10V?
If you use an established standard, you'll have lots of info on bitrate possible, distance achievable and
lower cost design because you can use off-the-shelf driver ICs.
Plus, more people can interwork to it.
