DrBudz
Junior Member level 3
I made some kind of Ethernet relay board. I designed the board to use RJ-45 connector with integrated magnetics.
The board is designed for 212A-11XA0-R-B-2 connector, but I couldn't find it later, so I bought this connector:
https://www.farnell.com/datasheets/17297.pdf
Here is the datasheet of the connector for which the board is designed:
View attachment 212A-11XA0-R_B_2.pdf
I am confused with the internal magnetics of these connectors, they look different.
Are those conectors interchangeable?
Thanks!
Thanks!
