losturcos
Member level 4
I am driving motor with IR2130(3phase) and controlling the IR2130 with PIC. I am using 5 12v/7a batteries.
The system is working like this:
First I am starting the motor to run to one direction for 2 seconds. I am measuring the current. Then I am
making the motor to run in reverse direction for two seconds. And I am measuring the current again.
I am checking which current measurement is lower, and then I am starting the motor to run to the lower
current direction which should be the easier direction.
While I am making tests at a motor which is not carrying load, it works as I think. But when I am trying this
in another motor which is carrying load, it happens reverse. I mean the current measurement lower in the direction
which is harder to run.
Do you have any idea about why this is happening? The IR2130 schematic is as below:
