Help neded for to do Scan Stitching by using RTL Compiler
manju540
Junior Member level 1
hello i want to know about SCAN STITCHING can any one explain what is SCAN STITCHING and the command in RTL Compiler
with adv thanx
manju540
Scan stitching is a part of the DFT(Design For Testability) process. Flipflops which pass the DFT DRCs will be converted into equivalent Scan cells(like MUXed scan/LSSD/clocked Scan). These scan cells will be connected serially when you stitch the scan chain. The scan chain will act just like a serial shift registers in scan mode.
And for RTL c0mplier command you can always browse through the rc_command_reference pdf.
tahnQ ranger01 ........................
