nosrej
Junior Member level 3
Hi! here's my confusion. V= IR so it is evident that voltage is directly proportional to current. But why do they say that as voltage increases, current decreases or vice versa. Does it have something to do if I'm considering the source side or load side?
Another question is, in op-amps they say that ideally the input impedance is very high while the output impedance must be very low. based from V=IR we need a high amount of resistance so that output voltage is increased compared to the input or amplified which is not what they say.
Please clarify and explain things to me.
