manikandan123
Member level 4
- Joined
- Jul 22, 2011
- Messages
- 76
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Location
- Bangalore,India
- Activity points
- 1,849
hi,
I used LM358 op amp. In my application I need voltage follower. the output is forward biased with diode.. So need to compensate the voltage drop on the diode. SO I want to get output, input voltage + voltage drop across the diode. so only we get same input as output after the diode. How do get it? when the input changes, the same output should come after the diode. Please suggest some ideas. awaiting for your response...
