[SOLVED] ihave problem in MPLAB IDE v8.80
imnimn
Junior Member level 3
I made a clear option and i get this message
"Couldn't locate build tool. Check tool locations."
-I'm work on MPASM suite -
although it still on my computer .i try alot of time and i don't success
HTML:
Language tool versions: mplib.exe v4.41
Tue Mar 27 19:02:52 2012
Clean: Deleting intermediary and output files.
Clean: Done.
i'm work on Release mode
When did you get this message? What applications did you install along with mplab?
please help me
---------- Post added at 21:28 ---------- Previous post was at 21:20 ----------
well i work with MPLAB without a prblem from more than month today i press clean -after MPLAB ask me to choose one languages to assemble with and i choose MPASMWIN 32 and MPLAB told me that build failed while it work in other computers hen i press clean - and this happen to me
---------- Post added at 21:31 ---------- Previous post was at 21:28 ----------
i install MPAM, MPLAB ASM30 suite,Third Party,MPASM Suite, MPLAB C32 suite,picc-9.83-win
before building did you include the source files and header files in the workspace..
in source files add your program file and in header files include the header file of the ic u are working with...
Tool locations can be set up in the project options.
Reactions: imnimn
    imnimn
what your opinion huzeeigat
---------- Post added at 21:48 ---------- Previous post was at 21:45 ----------
i have include them
but i don't know what shall i do in project options.
FvM is correct u can set tool locations from project options...select the mpasmtoolset from there and try...
---------- Post added at 23:23 ---------- Previous post was at 23:21 ----------
Go to project ->set language tool locations-> MPASM toolsuite..
FvM
do you think that i shall check tool locations but i don't know from where
---------- Post added at 21:55 ---------- Previous post was at 21:54 ----------
okay I did that and I get the same result
---------- Post added at 22:03 ---------- Previous post was at 21:55 ----------
thank you very much it's done
now i did that from select language tool
---------- Post added at 22:04 ---------- Previous post was at 22:03 ----------
thank you very much huzeeigat
thank you very much FvM
