phanikodali
Newbie level 5
For my mixed signal PCB to work i need the following low noise power supplies:
+12V/5A
+5V/3A
+3.3V/2A
+1.8V/0.2A
-12V/2A
-5V/3A
my application includes noise sensitive components like 16 bit high speed ADC, several low noise and precision op-amps, 12 bit DAC and noise generating components like Stepper motors(+12V/0.4A each) and digital circuitry.
i would like to generate the above mentioned supplies from +15V/-15V SMPS (having sufficient current rating) using dc to dc switching regulators(single output like national's LM22678TJE-5.0,LM22670MRE-5.0,LM20333MH or multiple output like LTC1876 from Linear) for positive supplies and LDO's for negative supplies(as high current rating negative switching supplies are difficult to obtain), is it the correct approach?
can anybody suggest me the best solution for the above requirements?
Thanks in advance
+12V/5A
+5V/3A
+3.3V/2A
+1.8V/0.2A
-12V/2A
-5V/3A
Thanks in advance
