zetinal34
Junior Member level 3
Suggestion** Microcontroller+ RF module for Capsule Size circuit (Pill size)
Hi all,
I am currently doing the project on gas sensor capsule. (swallowable)
I'm very new to micro-controller and rf module.
I really need help and advice on what micro-controller and transceiver I should use for this project
The requirements are as below
-Small dimension, Pill size (Both micro-controller and transceiver)
- Low power
- Transmission frequency = 400MHz band (It is safe for human tissue as I know, I'm not sure 2.4GHz will be ok or not)
- be able to control and manage data from sensors (around 4 sensors)
From the research I did, I found that there are some system on chip (SoC) available. It looks convenient, However, it can't be program unless I have the development kits. I only have budget around $200 which is not enough for some development kits. (Please advice if there is other way)
Can someone please give recommendation for the chips in this case? I have done some arduino project, so I'm familiar with C/C++, it would be better if I can develop using C language.
Please let me know if there is any different approach.
Any advice is welcome and appreciated.
Thank you very much.
Hi all,
- Low power
