munzir
Full Member level 6
how this controller will provide the output ?
https://www.jumo.de/products/pl70/702040/jumo-itron---compact-controller-702040.html
JUMO iTRON 32, Type 702040, 48mm x 24mm format
can we supply the 24 Vdc at terminals N & L1 (+ve 24 Vdc & ground)........ Also supply 24Vdc to connector screw 9 so that the relay produce the output at terminal 8 ........ Would it produce the output ?
If it would then can we use it as a A1 (coil voltage 24 Vdc of the contactor) ?
thanks
thanks
