skywalker898
- Joined
- Jan 31, 2012
- Messages
- 32
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Madison, WI
- Activity points
- 1,622
Hi, I would like to use a use the +5V digital output of an arduino to control a MOSFET switch, that simply has a +20V DC power supply attached to the drain in series with a 2k ohm load; the source is grounded. I have never used a MOSFET as a switch, so I am wondering if the circuit diagram I have uploaded will work **broken link removed**, and what parameters on a MOSFET datasheet I should be concerned about to make sure this works. If the circuit will work, does anyone know of any standard MOSFETs that I could use to build this?
Thanks,
Brandon
Thanks,
Brandon
