makanaky
- Joined
- Feb 1, 2007
- Messages
- 104
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 1,944
Hi can you please tell me what's wrong with this VHDL code as I get these errors :
ERROR:HDLParsers:3312 - "C:/Documents and Settings/ahmed/projectat/components_trial.vhd" Line 42. Undefined symbol 'std_logic'.
ERROR:HDLParsers:1209 - "C:/Documents and Settings/ahmed/projectat/components_trial.vhd" Line 42. std_logic: Undefined symbol (last report in this block)
Code :
Code :
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity xnor_gate is
port (in1 : in std_logic;
in2 : in std_logic;
out1 : out std_logic);
end xnor_gate ;
architecture x of xnor_gate is
begin
out1<=in1 xnor in2;
end x;
entity and_gate is
port (ind1 : in std_logic ;
ind2 : in std_logic;
ind3 : in std_logic;
ind4 : in std_logic;
end entity;
architecture xx of and_gate is
begin
out1<=ind1 and ind2 and ind3 and ind4;
end xx;
entity components_trial is
Port ( a : in STD_LOGIC_VECTOR (3 downto 0);
b : in STD_LOGIC_VECTOR (3 downto 0);
op : out STD_LOGIC);
end components_trial;
architecture Behavioral of components_trial is
component xnor_gate is
in2 : in std_logic;
end component;
component and_gate is
port (ind1 : in std_logic;
end component;
signal w,x,y,z : std_logic;
begin
u1:xnor_gate
port map ( in1=>a(0) ,
in2=>b(0) ,
out1=> w);
u2:xnor_gate
port map ( in1=>a(1) ,
in2=>b(1) ,
out1=> x);
u3:xnor_gate
port map ( in1=>a(2) ,
in2=>b(2) ,
out1=> y);
u4:xnor_gate
port map ( in1=>a(3) ,
in2=>b(3) ,
out1=> z);
u5:and_gate
port map ( ind1=>w ,
ind2=>x ,
ind3=>y,
ind4=>z ,
out1=> op);
end Behavioral;
