question about : conv_std_logic_vector
omar-malek
Member level 5
Member level 5
French
hi to all
is this correct to vhdl:
can any one explain me :
Data_reg = conv_std_logic_vector(13, 8)
with:
Data_reg = conv_std_logic_vector(13, 8) ;
thanks
neither is correct.
It should be:
Data_reg <= conv_std_logic_vector(13, 8) ;
But it's advisible to use the NUMERIC_STD package instead of the STD_LOGIC_UNSIGNED package.
Define your vectors as type unsigned ( or signed ) and use the "to_unsigned" function instead of conv_std_logic_vector.
conv_std_logic_vector is not a standard VHDL function. you should use to_unsigned or to_signed from numeric_std instead.
slv <= std_logic_vector( to_unsigned(10, 8) );
Reactions: shaiko
    shaiko
TrickyDicky,
You say:
"conv_std_logic_vector is not a standard VHDL function"
Is std_logic_vector a standart type ?
If not, is there a reason to use it besides compatibility with other designs ?
Refer to the std_logic_1164 package.
std_logic_vector is defined as:
TYPE std_logic_vector IS ARRAY (NATURAL RANGE <>) OF std_logic;
Is it a standard type then? I guess not because it is derived of std_logic (which is a subtype of std_ulogic), but everyone will say it is, as it is defined in std_logic_1164.
Reactions: shaiko
    shaiko
TrickyDicky,
You say:
conv_std_logic_vector is defined in std_logic_arith, which we want to avoid.
std_logic_vector is defined in std_logic_1164, which we want to use.
Reactions: shaiko
    shaiko
TrickyDicky,
You say:
Generally speaking, when people say something is or isn't a standard in VHDL, what they mean that it is or isn't released in the IEEE standard. std_logic_vector is part of the IEEE standard so it is considered a 'standard', whereas conv_std_logic_vector is not part of the IEEE standard so is not considered a 'standard'. As pointed out, the function 'to_unsigned' will do what 'conv_std_logic_vector' is trying to accomplish, 'to_unsigned' is part of the IEEE standard.
Kevin Jennings
Reactions: shaiko
    shaiko
so i will explain where i used this function
in my design i receive a frame folowing a standard my frame is 16 bits, so to detect this frame i use a counter this counter count the number of receive bits
and this received bit has a value like 11110000110 .
