[SOLVED] variable resistor in proteus
electroboy
Member level 5
Member level 5
how to use a variable resistor in proteus ? i does not allow me to change the resistance value during simulation... please help..
When You Search Component...
Type
"POT-HG"
This Will Surely Help You
This is the Snap of the Image..
Hope this Helps
arunsharma0731 has already told you what to select.
Just remember that in Proteus, when you want to simulate a component, you should select an "ACTIVE" component (written under the LIBRARY column). POT-HG is the only active variable resistor that allows you to change the resistance during simulation run-time.
Hope this helps.
Tahmid.
You can change the value of the variable resistor by dragging the arrow leg of the resistor.
all of u correct boys
but where is the asker
Anwar2
