Alosevskoy
Member level 3
- Joined
- Oct 11, 2011
- Messages
- 55
- Helped
- 19
- Reputation
- 38
- Reaction score
- 19
- Trophy points
- 1,288
- Location
- Zelenograd (Moscow)
- Activity points
- 1,634
Hi, guys!
I'm using SOC Encounter as a layout tool. I need the florplan depicted below:
The problem is the tool uses hard blocks sizes while calculating CORE size. So the question is how to exclude them from CORE size calculation (it should be determined only by Digital_Logic module).
The hard blocks are represented in LEF files.
