Export microstrip antenna gain from hfss using Matlab
Simos421
Newbie level 6
Newbie level 6
Hi! Does anyone know how to export the calculated gain (Gaintotal db) from hfss using Matlab-Hfss Api's functions?
Hello
I dont know the direct way of doing it,but you can export the file into.txt,.csv format and then read the .txt file into matlab.
Elchachito
Thanx Elchachito, i know that, but i need a script to do that automatically through matlab....
Hello Simos
Check this link. let me know if its helpful
Elchachito
...Sadly this only exports return loss of the antenna.....
Brother you have to change the file names and values to get what you want.if you are looking for a file specific to your requirement,i would say all the best. you have an example file.try working around with it and write your own script taking inspiration from this file.dont think there will be any difference between return loss and gain, its just how and what you call in the file
Elchachito
Actually it's not that easy as you might think...
i wish you all the best.Hope someone will find a file for your requirement or someone already has one that has already compiled.
ELchachito
