What's the AT command for acquiring BTS location using sim300 gsm modem?
binojkumar
Full Member level 3
Full Member level 3
Bangalore
Hi friends im using sim300 gsm modem in a project.
For getting the local information(name of the place where the tower is located) wht command i should use?? pls help me
Thanks in advance.
sim300 gsm module
hi
i never found such AT command in sim300,as far as i know Location of a BTS is the information send by operator as data,which is decoded and displayed in cellular phones,if u know the format of data u can recover the Location.
Shakeel
sim300 gsm
Hi...
Have anyone details of pinout sim300?
i want need to sim300 hardware pinout description.
can you help me?
regards.
gsm modem sim300
Search for SIM300_HD_V2.02.pdf or newer versions on the internet,
e.g. **broken link removed**
Regarding the above questions, the registered cell information can be retrieved with any GSM modem by +CREG command, but you need to know the base station station numbers.
gsm sim300
Hi....You can contact Mr.Ganesh to buy this product.We purchased it from him for our projects.It is working fine.It supports all AT commands.You can purchase from him for the best price compared to the market rate outside.
Contact person:Ganesh
Mobile:9xxxxxxxx
MOD: Instead advertising for Ganesh in every post of your's invite him to EDA board where members will truely benfited by his sugessions and guidance if he likes to share his knowledge.
gsm sim 300
There are several versions of SIM300. The one which I am using is SIM300CZ. If you could give me exact detail, I can assist you finding correc pinout. I can also give you AT command PDF. but you can try SIM300ATCommand.pdf which has all the necessary AT commands.
sim300 gsm modem
Heyy
i use AT+CSCB=0,"50","1"
to get the BTS location..!!
Hope this helps you!!
Please take into consideration that +CBM messages are enabled. This can be changed by AT+CNMI..
Refer to AT command set manual for more information!!
Surya
gsm module sim300
Hello ,
In response to at+cscb command I got following.
at+cscb=0,"50"
OK
+CBM: 16170,50,1,1,1
DOSTI 5432160 (FREE)
can u please suggest me how can I get location information?
Thanks in advance.
Anand
sim 300 gsm module
For more info on the values refer AT manual of your Module
This is the location information that is being provided by your operator:
This is actually the intended location information, but the operators prefer to show adds to promote the advertisers.
Surya
sim300 price
Thanks a lot Surya.
Rgds
Anand
sim300 gsm module price
I'm looking for low cost GSM modem..Would like to ask how much is this sim300 GSM modem as well as the contact info as to where I can purchase it?..Thank you...
sim300 pinout
Hello
For SIMCOM modules you can contact directly.They will tell you the distributor name if the quantity is less otherwise they will directly send.
Avnet is one of the distributor for SIMCOM modules.
Anand
driver modem gsm sim300cz
How much does a sim300 gsm modem cost?..Thank you..
gsm modem commands pdf
Hello
For approximate price you can have a look over this link.
Anand
Re: sim 300 gsm module
hellow,
can you pls give me the database of celltower id's?
i tried all the at commands.with sim300..pls check this;
AT
OK
AT+CENG=1
OK
AT+CENG?
+CENG: 1,0
+CENG:0,"0069,35,0,404,72,44,dd7d,06,05"
+CENG:1,"0078,34,44"
+CENG:2,"0088,18,53"
+CENG:3,"0074,14,44"
+CENG:4,"0065,11,53"
+CENG:5,"0066,07,48"
+CENG:6,"65535,00,255"
what is my tower id?.......how can i retrive it?
---------- Post added at 16:17 ---------- Previous post was at 16:10 ----------
hellow,
AT
OK
AT+CENG=1
OK
AT+CENG?
+CENG: 1,0
Hey friend you have used exact command
that is AT+CENG=2
this AT command will show you the following format
in the above format 0069 is the ARFCN frequency which your mobile handset is servicing
404 is your Country code
dd7d is your CELL ID and you will have to convert this cell ID into decimal format
i have converted for you
your mobile phone CELL ID is dd7d=56701
in that your operator SITE ID is 5670 and 1st sector is servicing to your cell phone.
you need a LAC(location area code) to find the cell ID based tracking
you will have to extract the CELL ID from the above string
