Serial to parrelel Shift Register
ismu
Full Member level 2
Full Member level 2
nil
Sir
I want a 16bit low cost 20mA output serial to parrelel Ic instead of 74HC595 ,it has only 8bit.
Which is more suitable ?
cascade more 74hc595
---------- Post added at 12:18 ---------- Previous post was at 12:16 ----------
For codes see here :- Interface to a 74HC595 Shift Register
Reactions: ismu
    ismu
74F675A, for example. Or you can try connect several 74HC595 in series.
Reactions: ismu
    ismu
•CD4006b 18-bit serial-in/ serial-out shift register
•CD4031b 64-bit serial-in/ serial-out shift register
•CD4517b dual 64-bit serial-in/ serial-out shift register
for more :-http://www.allaboutcircuits.com/vol_4/chpt_12/2.html
Reactions: ismu
    ismu
sorry, of course I meant 74HC595
