bmandl
Full Member level 4
- Joined
- Feb 26, 2010
- Messages
- 210
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- Slovenia
- Activity points
- 3,006
Hy guys.
I need your help. I am building a high power led matrix and I need advice on how to connect individual leds. I have a 260x160mm heat sink, where I will mount star PCB leds. PCBs are 20mm wide and I need to space them 3mm apart from each other for lens to fit on. So I can put them 11x6. It doesn't really matter for conection, but anyways... I have a 200W 6A 18-34V led driver for my matrix. Leds are 400-415nm so forward voltages are somewhere between 3.5-4.0V, and current is 700mA. So how should I connect LEDs to a power supply in the meaning of serial-parallel connection, so that I won't damage any led and that all would be as bright as possible?
Thank you.
Thank you.
