How to design a DC-DC to let output voltage follow the input voltage?
diego.fan
Member level 3
Member level 3
How to design DC-DC to let output voltage follow input voltage?
Hi, all
Could you please give me some hint? I'm totally new in this DC part.
I want to design a circuit:
DC input, voltage changes from 0 to 4V
DC output, voltage follow input to change. For example,
input=0, output=0
input=1, output=1
input=2,output=0
input=3,output=1
input=4,ouput=0
Like below, xaxis is Vin, y axis is Vout. Which kind of circuit or architecture should I use?
Re: How to design DC-DC to let output voltage follow input voltage?
Better to use a micro controller having ADC and fix the voltage tolerance (for 1 volt consider 0.9V to 1.1V)
This requires a more complete specification.
Voltages available, frequency response, power-handling needs...
Ignoring any other requirements that may be there the easiest way is to just short the output to the input :smile: but I assume you can't do that since you need to drive something from the output which the input cannot do. For that the easiest way is to use an opamp in the voltage follower mode like shown here http://www.learningaboutelectronics.com/Articles/Voltage-follower. Now you may be able to get away with this simple solution if your specs allow you to choose a suitable opamp that can satisfy them.
Are we to assume that between the points you have
declared, it's linear interpolation as the graphic shows?
Simplest could be ADC, cal-map xyzROM, DAC (but this
will be "steppy" at lower bit-widths) reading VIN and
driving VREF with appropriate feedback network.
You might also be able to use a VIN "thermometer"
comparator cascade, and analog switches across
subsections of the feedback network and perhaps
a VREF source network, to make the ups and downs.
Poor-boy version of ADC (comparators) and DAC
(switches), and the ROM is you.
I am a bit confused to what is required.
Are you talking about a function like this below?
Using a difference amplifier you can create either a rising slope or falling slope as shown in the image. All you need to do is detect in which region does vi lie and then connect the right signals for v1 and v2 of the difference amplifier. If the change boundaries are 1,2,3 volts then you need 3 comparator and some simple logic to switch the right voltages to the input of the difference amplifier.
aryajur, I agree with your proposed method, and my plots were obtained with a similar circuit. We still need to get clarification if this is the wanted transfer function.
I think a Schmitt Trigger will serve with a carefully selected threshold voltage.
Below is the circuit, I used to generate the function. I am sure it could be simplified, but I didn't bother with it any further once it worked.
Reactions: d123
    d123
Thanks a lot!!!!!! Please give me some time to understand what you say.
Supply voltage is 2V, I want to get positive voltage and negative voltage which are as large as possible. The output voltage can change following the change of the input voltage. Vout could be similar to the picture, it can also be sine wave or cos wave.
Frequency response and power issue are not required. maybe there is some requirement, but for me the first priority is to have a basic idea about which kind of structure I can use. So I don't consider frequency response or power yet.
Thanks!无标题.png I think I forget to draw something. Is it possible to generate +/- voltage based on input?
Sorry to let you confused. I don't draw it clearly. It should be like this below. The output voltage can be triangle, sine or cos wave, it doesn't matter. Anyway, Vout can follow Vin to change to positive or negative value.
Thanks a lot! I am trying to understand what you say. May I ask is it possible to generate positive and negative voltage using these circuits?
Thanks aryajur!!! May I ask does this circuit can generate positive and negative voltage based on , for example [from 0 to 2V] supply voltage?
Not impossible, but what's the purpose at all?
The non-linear, non-monotonic Vin to Vout function requested in post #1 has been understood as analog circuit design problem in the first place. As the circuit elaboration by E-design clarifies, this design aspect is already quite challenging. You need in fact a dedicated comparator or equivalent circuit function block for each of the three break points in the Vin/Vout characteristic and additional circuit elements to transfer the comparator result to the output, e.g. the suggested analog switches.
The thread title "let output voltage follow input voltage" is mostly misleading, I fear.
Asking for a specific power supply, e.g. DC/DC up-conversion or polarity inversion is an additional requirement, it would be usually implemented independent of the non-linear voltage characteristic.
In case the term "supply voltage" is meaned as another word for "Vin" in the original diagram, I'd say it's still possible, but even more complicated.
It is not difficult to offset the output of the current circuit to go positive and negative, but as FvM stated anything beyond this gets messy with just analog design tools.
I would also like to know what the purpose of all this is? There may be other ways of achieving your goal.
Thanks,FvM! I repeat my understanding based on your reply.
1. Voltage comparator is required to decide the breaking point of Vin. For example, when Vout begins to increase, when it begins to derease,when it go to negative voltage. All these breaking points need comparators to decide.
2. For positive Vout, E-design's sch is a good start point to learn
3. I search the website and found a lot of circuit about transfering positive voltage to positive and negative voltage at the same time. But they are all fixed output voltage. I really don't have idea about how to generate changing negative voltage which are also a function of Vin.
4. There are no requirement of "a specific power supply, e.g. DC/DC up-conversion or polarity inversion".
5. The supply voltage is 2V, which is fixed. The input signal is a changing voltage,maybe 0-1V or 0-2V, it doesn't matter. The output signal has different function of Vin in different range of Vin, as I draw.
Thanks,E-design. This is my assignment which don't have practical purpose. Because I am a new EE in DCDC, I have no idea about how to do the first step or what I should search in google. Because I search "generate negative voltage", but I can only find "generate fixed positive and negative voltage" but not this kind of changing positive and negative voltage.
