el00
Member level 5
- Joined
- May 27, 2009
- Messages
- 91
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 2,225
Hi, I have a board (Vbus is 160V) with few amplifiers on it that send short bursts to a load. The peak absorption is about 20A for 5ms (every 1s). Since I want to parallel some of them, I will have peaks of ~200A.
I want to perform some test by paralleling 100mF, but the problem is that I need to separately power the board, charge the capacitor and then close a switch that connects the capacitor in parallel.
I am pretty sure this is a common situation with large capacitor: do you know if there is some commercial chip that acts as a controller in such a situation? I would like this to be automatic.
Thank you
Thank you
