arun_190175
Member level 3
- Joined
- Oct 22, 2014
- Messages
- 60
- Helped
- 14
- Reputation
- 28
- Reaction score
- 14
- Trophy points
- 1,288
- Location
- INDIA\RAJASTHAN\CHIRAWA
- Activity points
- 1,574
of course design is old but one thing i can't understand that when port drive segment my question is that key0 or key4 both pressed then corresponded segment are disturbed(two segment are short)Thats not a clever design. It uses the segment drives as row and column drive/sense lines and has no pull-up/pull-down on the inputs. I would anticipate some strange segment patterns and indeterminate input from the keypad when any two or more keys are pressed simultaneously.
Note the design is 24 years old and uses a long obsoleted PIC. It is only intended as a demo of the ADC inputs, not for practical use.
Brian.
Obviously the signals of RB4 and RB5 after the resistors are shorted.
Don't know what these lines are used for, because there is no information in your schematic.
Klaus
The idea isn't bad: The display needs to be nultiplexed anyway. Why not with the same wires multiplex the keypad...
A little hardware, and a little piece of additional software and you gain full keypad functionality.
A series diode with each pusbutton, and maybe pullups...and it should work.
Klaus
No.yes i agree with you need some diode or some pullups thanks
