VSef
Newbie level 6
- Joined
- Nov 14, 2012
- Messages
- 14
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,283
- Activity points
- 1,418
Hello,
I have a project where I need to design a power supply that is connected to the grid (230Vrms, 50Hz) and has two output voltages. The grid's voltage isn't rigid and varies between 140-250Vrms.
My power supply should have 2 outputs with galvanic isolation:
- Output #1 supplies 24Vdc +-5% with a maximum current of 150mA.
- Output #2 supplies 5Vdc +-2% with a maximum current of 100mA.
Linear regulators aren't an option because of its low efficiency and the huge amount of heat it needs to dissipate. So switched mode power supplies are our only option.
What do you think is the best design to come up with?
2 buck converters with a 50Hz transformer on input? Flyback converter? Sepic?
Thank you
Thank you
