Techman_7
Full Member level 2
- Joined
- Dec 21, 2013
- Messages
- 143
- Helped
- 0
- Reputation
- 0
- Reaction score
- 1
- Trophy points
- 1,298
- Activity points
- 2,446
I am working on single phase ac motor drive project.
The schematic is attached only for H-bridge.
I have generated SPWM signals using opamp. When I connect resistive load I get the AC output voltage as expected. But when I connect 150 watt AC motor of washing machine, the motor rotates for few seconds and then my input fuse BLOWS.
While testing I give SPWM signals to H-bridge first, then slowly apply the AC input voltage through variac. At AC input of around 60-65 VAC the fuse blows with driver IC damaged.
Sine wave is of 50 Hz , Triangular wave is of 15 KHz. Driver Vcc= 15V. I am first trying to run motor without any feedback.
I guess the values of gate resistors should be optimized. But these are as per to limit current capacities of IR2104 driver.
Can anybody please help ....
