RenesasT
Full Member level 2
- Joined
- Mar 11, 2016
- Messages
- 149
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 16
- Activity points
- 1,330
Hello All,
Again, I need one more help on the sensored BLDC motor.
I am developing a driver which is having max current protection 20A. The motor is driven on 12V and 24V.
The motor is 3 phase BLDC motor.
My driver gives motor speed as 1800 RPM at 24V ,1.3A without load and 900 RPM at 12V,0.9A without load.
I have checked other 2 and 3 drivers which has dedicated IC in the circuitry for BLDC motors. They are giving following speeds,
2000 RPM at 24V , 1.5A current
1100 RPM at 12V, 1.1A current
My project is to change those dedicated IC's with micro controller. I have implemented and its working fine. All functionalities are working fine.
The project is not acceptable because of speed characteristics are not matching. Other functions are OK. Just speed characters are not fine,
It would be 1000000000 times helpful for me if you all guys will help me in this issue, So that I can submit my project.
Awaiting for your reply.
