edachlor
Newbie level 2
- Joined
- May 8, 2017
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 35
I have this old black rotary dial phone which I want to connect it to a GSM module and microcontroller.
The bells will ring at 24 VAC but they sound better with 48 VAC (no sound at 6 VAC). Inside the phone there is a schematic telling the bells has 1000 Ω resistance. I calculate that to 50VAC/1000Ω = 0.05 A, and 50VAC²/1000Ω = 2.5W.
Now I want to make 50VAC from a 3.7VDC battery based on this inverter schematic with two MOSFETs.
I have found this 1x240VAC to 2x18VAC 50mA transformer and when connected to a square wave of 3.7VDC at 50Hz it should give 240/18*3.7 ≈ 50VAC.
On the battery side it should give a load around 2.5W/3.7VDC = 0.68A.
Should I just choose MOSFETs which can handle 1A?
Is that how it works with transformers and inverters or have I misunderstand/miscalculated something?
The bells are suppose to ring for ½ a second (I think) and then with 1 second pause. I don't expect the transformer to became too hot.
