mamech
Full Member level 3
- Joined
- Nov 9, 2010
- Messages
- 176
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 3,135
hello
I have a strange problem. We use in our application the Power IC ADE7953 , and it gets its supply from a smps DC supply (1 A rated). It gives good measurement and it has no problem when it is connected alone, but when connecting wifi module of our project to the same DC source, the Power IC get blind in low current ranges (currents less than 20 mA), while it is still relatively good in high ranges. After several trials, we became sure that wifi makes some unknown behaviour that destroys the measurement of Power IC in low ranges. I know that we should have used smps supply with isolated channels, but sadly we have already bought the components. Are not there any suggestions about how to eliminate or at least reduce this effect?
