alexxx
- Joined
- Apr 17, 2011
- Messages
- 1,013
- Helped
- 273
- Reputation
- 552
- Reaction score
- 270
- Trophy points
- 1,383
- Location
- Greece
- Activity points
- 7,936
I need to drive a 24V/27A DC motor (650W). This motor must operate even when mains power is off, so a 24V lead-acid battery will be used. The trasnformer will be 1KW. My concern is the power dissipation on bridges, diodes and mosfets when the motor is moving. The following components seem sufficient for the job.
https://export.farnell.com/multicom...sp=All&searchView=table&rpsku=rel3:KBPC5004FP
https://export.farnell.com/infineon/ipd50p04p4l11atma1/mosfet-p-ch-40v-50a-to-252-3/dp/2443434
https://export.farnell.com/on-semic...meResp=All&searchView=table&iscrfnonsku=false
But the problem is the total power dissipation. For example the diode will have a voltage drop of 0.3V, at 25A this will be 7.5W. The mosfet will dissipate something less than 7W and the bridge more than 20W!
1. I think that a good idea is to mount the bridge on the transformer, for the best possible cooling. On the other hand maybe I could use a DC power supply at 1KW, to avoid the use of the bridge. But could a powerful motor be driven from such PSUs?
2. About the schottky diode and the mosfet, if I use convencional components with a heatsink on them, would this be enough for 7-8W?
3. Can anyone suggest a thermal protection for the motor? A simple NTC (ie at 40A) would be OK? Or something else must be used for such high dc motor currents?
Thanks in advance.
Thanks in advance.
