flabbergastt
Junior Member level 2
Hi guys,
This might be a vague question, I'm still quite new to electronics. I have a two stage op-amp attached below that is simulated using LTSpice used as a buffer amplifier. Suppose that it operates as a low voltage buffer (supply is 0v to 2v, input is 0 to 2v, so output is 0 to 2v) limited due to the low voltage transistors in the circuit.
Suppose now I want it to be able to output 0 to 10v, so the input and supply is also between 0 to 10v. How could I effectively do this? I have higher voltage transistor models in LTSpice, could I just replace all the lower voltage transistors with higher voltage transistors?
any input is appreciated!
thanks
thanks
