[SOLVED] MinGW installation problem need help
vead
Full Member level 5
india
I would expect a different order on the command arguments issued from what you did, as :
gcc hello.c -o hello
I tried that command but its not working. Showing same error
The most likely suspect...don't use directories with spaces in them Mr embedded is probably the issue. work with your code in a directory that has no spaces.
Mr embedded is my system name. I don't think it does matter. I think there may be problem in path variable. if you see given link there is step for path variable. but when I click on edit button I don't see new window
gcc is executed, obviously the path is O.K. (unless you're starting a different gcc instance than the intended in mingw bin directory).
The above error message clearly indicates the OS is finding the gcc.exe executable just fine. What the OS is not finding is the hello.c file on your desktop.
Execute the following command and post results:
gcc -v
BigDog
gcc -v
BigDog
I have attached result please look at image
I've examined the results and compared your results with mine.
The only major difference, apart from the make and version number, is the COLLECT_GCC environmental variable:
yours
COLLECT_GCC=gcc
mine
COLLECT_GCC=C:\MinGW\bin\gcc
Although, I doubt that is the issue. What is the specific location, i.e., directory path, of your hello.c file?
BigDog
yours
COLLECT_GCC=gcc
mine
BigDog
directory path C:\MinGW\bin I have created hello.c file on desktop
Please execute the following command from the command window:
dir -l hello.c
Post a screen capture of the result.
BigDog
This is screen shot
Obviously, the hello.c file is either not located in the current directory:
C:\Users\Mr Embedded\
Or the full file name is NOT:
hello.c
Execute the command:
dir /p
Carefully look for the C source file, double check there is not an extra extension like, hello.c.txt.
If no file is found in the current directory you will need to locate the specific directory which contains the C source file and then CD to the proper directory.
By the way, the current command window is not currently in the Desktop directory.
BigDog
Reactions: vead
    vead
BigDog
Problem resolved, There was wrong file hello.c.txt. I have corrected it. Now I can compile program
Thank you very much BigDog
Unfortunately, it is a common issue encountered on Windows OS environments, users open source files in text editors like Notepad which add the txt extension to the file by default when saved.
BigDog
